Stock settings
Stock settings
I have a revo and have about 6 tanks through it and I can't get it to run right. It starts ok goes off the line ok but then has no power. Also stalls alot. I want to reset all the neddle valves and settings to stock to start over maybe something is way off since I have messed with these alot. how many turns out should this stuff be set to.
My Feedback: (-1)
RE: Stock settings
well, really there isnt a reliable way to find the stock setting.
So just richen the air/fuel mix (turn to the left) and leave the idle where it is.
Now drive the truck until its at normal operating temp, then start to lean it out until you notice there is no more fuel coming out the exhaust. this will leave you right at tuned
