2 speed tranny
PA
2 speed tranny
I have the Revo, and I am having problems getting it to shift. I am sure my carb was set ok because it ran fast but would not shift, I tried to adjust the the high speed mixture but it started to overheat with no more performance improvement. So I set it back a little it was running around 270 average in an ambient temp of around 60 deg F. So I adjust the transmission, I loosend the set screw inside a little didn't work did it some more didn't work. Loosend the slipper tightened the slipper. No Luck. SOMEBODY HELP ME!!!
[&o]
[&o]
PA
RE: 2 speed tranny
get ur truck tuned the way u want it and u said it was going fast and wont shift so u could tighten the tranny screw cause it could be starting out in 2nd gear
