Fuel Leak... Bad Motor?
I have a pro .15 and fuel leaks out around the start shaft, and makes the one way bearing slip. Then the ez start wont turn it over. I mean there is fuel dripping of the chassis when Im done running It.
GA
RE: Fuel Leak... Bad Motor?
Some people drill a small hole in the ez-start backplate so that they can shoot cleaner (wd40 works too) at the owb w/o taking everything apart. Or, you could replace the shaft and bushing. OR, there's always the OS.18CV-RX(s)-direct swap or the OS.18TM.
