I know this comes up alot but...
VA
For you T-Maxx guys. What is the best performing engine and biggest engine out there for our trucks. I have the 2.5 right now but when it goes I might try something else but I want you opinions. I am personally looking for a high torque high speed motor. I was looking at that 4 stroke setup but wasn't sure about that. So lets hear it.
RE: I know this comes up alot but...
572 cu.in Merlin Chevy......
ORIGINAL: racintang
I see a lot of people putting XTM engines on the T-maxx. If you're considering an XTM engine, get the XTM 457 or the 24.7 Pro. The 457 will be extremely powerful for a T-Maxx, but you said you wanted something powerful. XTM also makes an XTM big block conversion for the T-maxx, so its always something to look into.
VA
Is the 457 a big block or will I be able to bolt that into place?
Also, are there any goods strong motors that will allow the use of the ez start? or am I better off getting the 3.3
VA
Does anybody know what the cubic inches and hp actually are for the 2.5 and 3.3. I have never seen them advertised.
VA
My next big question is for ssj2. I don't know much about what will bolt into what without conversions. I can doa gas car all day lng and feed you info but this is different for me so ssj2 will the 24.7 or the 457 bolt in?
CA
ORIGINAL: racintang
Is the Picco 26 or the Novarossi 528 XR any good.
You see engines advertised at 3.8hp or sometimes even more (CEN 5hp) but that is all claimed. A dynometer tell the true HP. A moded Novarossi makes about 2.1hp on the dyno.
Check this out:
http://www.nitrodynesystems.com/Engine%20Database.htm
Just so you are aware, if you drop in a HUGE engine with lots of power, be prepared to replace diffs, trans parts and drive shafts. They won't last too long with a huge increase in power.
IL
No true "Big-Block" drops right into a T-Maxx. You need a big block conversion, which is worth it I guess, but if you want a big block without having to convert anything, the closest thing would be the RB TM323/523 or the Picco .26. I have heard more bad things about the Picco then good, so I suggest the RB TM323/523.
BTW, I personally have a TRX 3.3 in my Revo, and I really like it. It is a really good engine for the price, and once mine kills itself(knock on wood), I am planning on getting another one. Or if I have the money, I will convert to a true big block.
OR
Get the RB .23 523 engine it has a pipe and manifold it the biggest engine you can use the ez start on....that motor has balls and torq
