Some help please...
Some help please...
Hi there. Here is a question I have not seen answered on the forum. When I try and start the engine using ez start, the fuel simply wont move through the line...even when I prime the engine and I know the fuel tubing is not leaking...what could be wrong?...thanks in advance...
GA
RE: Some help please...
With the info you've given I'd say to check the fuel tank lid seal first then the coupler and the header gasket next.
Any other symptoms/problems? Like runnig hot/lean, cutting out/dieing for no other apparent reason, hard to start, etc?
