just installed voltwatch meter, is it supposed to be doing this?
http://www.youtube.com/watch?v=Ku1a0CaltB8
is it supposed to be lighting up all the way like that when i move the wheels and throttle
MI
RE: just installed voltwatch meter, is it supposed to be doing this?
Sort of, yes. It appears that your throttle servo is drawing alot of power. It is normal for the voltage to drop when a servo moves, yours just drops a huge amount.
So, in essence, yes, the Voltwatch is functioning normally. You might want to check how well your battery performs though.
What kind(s) of stearing servos are you running? If you have two high powered aftermarket servos, you might consider swapping them out for just one. It seems like that is where most of your power drain is comming from.
ive got one hitech 5997 for steering and stock for throttle, i was just unsure if when you move the wheels and throttle if the lights on the meter were all supposed to light up
MI
Yeah, it's normal for it to do that. When you put a load on the power (turn the servo) the voltage will drop, which is what the voltwatch is indicating. I wouldn't worry about it too much.
ive got another quick question, ive got a spektrum throttle servo that i think is toast, i made a little video showing how bad it shutters to the point where i think it was causing my idle problems, i tried putting a stock traxxas servo back in but no matter what i did i couldnt get the throttle to open all the way up
http://www.youtube.com/watch?v=d5xhCvBr6q4
LA
is it on a revo? cause i had the same problem and it turn out to be the return spring it had to much tension so i change the spring for the one that the savage uses but you have to do some cutting for it to fit!!
LA
oh and i upgraded to the ball bearings throttle mixer!!
http://www2.towerhobbies.com/cgi-bin...?&I=LXLNT3&P=7
Are you using a Spektrum radio? If so you can adjust your transmitter for your servos.
ORIGINAL: Indecline099
OH
