TMaxx 25 Stock Needle settings
My Feedback: (31)
IL
What's a good starting point for a Tmaxx 25? Regular TRX .15 engine.
I turned the main in and counted 3 5/8 turns. It seems pretty high to me, but I'm only used to plane and heli engines.
What about the low end?
Bandana
Bandana
MT
RE: TMaxx 25 Stock Needle settings
I beleave its 3 and 1/2 turns out form closed on the hsn and on the lsn you want it to be flush with the little arm that conects to your servos that makes your carb slide in and out. Just when you close your hsn or lsn, go until it starts to get tight nad stop, NEVER make it supper tight or it cna damige your carb or neadle.
LA
