Upgrades for Bashing (TMAXX)
What upgrades for the tmax would be recommended for bashing? So far everything seems to be holding together as stock but I'm sure something will break.
PA
RE: Upgrades for Bashing (TMAXX)
ORIGINAL: Infinite Gundam
Personally I would not fix anything that's not broken, unless you want to add some bling to your truck.
The first things to get are a failsafe and a throttle return spring.
After that, replace/upgrade parts as they break. My first maxx issues that needed upgraded were the a-arms, hinge pins and turnbuckles ( I used to hit a lot of stationary objects when I was learning to drive)
When you start breaking things repeatedy, you can upgrade them. RPM plastics are great, and I seem to have good luck with Lunsford for the titanium parts like turnbuckles and hinge pins...
