non-working engine... help!!
MI
i have had a traxxas rustler for about 3-4 months, and after changing glow plugs, gas lines, setting the carb to factory settings, the engine still wont start. any ideas on why? i have some pics of the engine.
RE: non-working engine... help!!
did you put fuel in the tank? lol do you have anymore details ? is it turning over and just not starting? did you try priming it?
check the O ring on the gas tank lid. that can cause an air leak. when u prime it is the fuel going into the engine or not moving at all?
MN
are you sure that the ez start is glowing the glowplug? make sure the end of the exhaust is free of obstruction. and if they are at factory settings try leaning them out a lil bit.
check if fuel lines have holes, check ez start. if it still doesnt work than try this link below. someone posted it on a forum and its an excellent way to check for air leaks in your engine.
[link=http://www.*********.org/engine-tuning.htm]air leaks[/link]
MI
i went to the LHS and bought a pull start and it starts fine now. urjustamemory, do you have a charged enough battery?
NY
ORIGINAL: BANDGEEK1
Yeah when I took it to the LHS they put a brand new battery in the ez start and it turned over so I had to buy a new battery for the controller.
NY
I would try using a glow ignitor then turn it over,cause my Traxxas 4-tec had that prob so i took that wire of completly and now use my glow ignitor then turn it and it fires right up,good luck with it.
