quicky question....
CA
quicky question....
im wrapping some fuel tubing around my engine head, so do i need any thingy to protect the tubes from being burned? like shrink tubing or something?
thanks
thanks
NJ
RE: quicky question....
no need traxxas gives out fiberglass heat shieding tube
Heat shield tubing, fiberglass (2) (yellow).......part no. 3149...........1.50
Heat shield tubing, fiberglass (2) (Black).......part no. 3149...........1.50
i like the black better, no difference in performance, and it depends on what color fuel line you run,
mine is neon green, so black looks best
100th POST
100th POST
GA
Wrapping fuel line around the head is a bad idea. You want to keep the fuel as cool as possable before it enters the carb. Besides, the Revo has a couple of clips near the roll bar to hold a couple of loops of fuel line, why would you even want it wrapped around the head?????
CA
the fuel nipple is pointing towrd the LSN and i forgot to move it. its already mounted on the engine and all that....for me, its a hassle to move it...and also i lost my roll bar. anyway, ill try to keep the tubes away from the engine and ill try to figure somethings out....thanks
ORIGINAL: RCCanuck
you don't need it but you can add some if it makes you feel better
