optidrive
VA
RE: optidrive
[color=#0033CC]the optidrive unit , works in conjuction with the reverse gear, it wont allow it to go into reverse until the truck has come to a complete stop. it also acts as a failsafe. if the blue {sensor} light isnt coming on anymore its not working properly UNLESS its jus the LED gone bad. try resetting it see if that helps
RE: optidrive
ORIGINAL: Art91
I would drop the opti-drive all together, put in a forward only conversion and get a good failsafe.
you dont need to go foc if you want to dump the failsafe though you will need a failsafe
