Losi Shocks
Losi Shocks
would team losi's monster truck shocks fit on a t-maxx? also, would they perform any better, other than give it more ground clearance?
RE: Losi Shocks
RE: Losi Shocks
ORIGINAL: drag racer
bump
bump
there to thik to fit in the holes in the a arms
you would have to put them on the outside you will have to mod a bit with brackets and that
RE: Losi Shocks
ok thanks but what about the rest of the shock.. would it be hitting the a-arm?
your going to have to cut the upper a arm which will weaken it and also the shocks could rub on the stock shafts so you may have to go with the metal ones
PA
RE: Losi Shocks
http://integy.automated-shops.com/cg...17107380997.d2
that should solve ur problem. there is no outside to them jus the middle.
and if ur gonna race ull need this for more tuning.
http://integy.automated-shops.com/cg...18107370597.03
