The charging emaxx
The charging emaxx
Is it worth the extra money to buy aluminum bulk heads for a traxxas emaxx istead of the original stock bulk heads that are like $8
RE: The charging emaxx
If you put aluminum anywhere it should be the bulkheads. Keep the stock body mounts and go with rpm a arms and you should be all good. Dont go aluminum a arms and body posts.
