New Engine
PA
New Engine
i want to get a new engine. but im not sure wat i want to get. i would like sumthin that is not costly, and i can still use my stock tranny and drivetrain in my t-maxx 3.3. i was thinkin of an os engine or a picco.
NC
RE: New Engine
OS or Picco is a great choice. I'd go picco for the extra power.
http://www.youtube.com/watch?v=pIDrqJUpKjg
PA
RE: New Engine
found a picco that will drop in and i can still use the ez-start
http://www.teampicco.com/Motori/p2.html
its a .26
its a .26
NC
RE: New Engine
http://www2.towerhobbies.com/cgi-bin...?&I=LXKHE9&P=0
you'll get $20.00 off that price when you order.
[link=http://www.towerhobbies.com]Click me[/link]
KY
RE: New Engine
I just put in a .26 picco, it's a powerhouse..Almost too much power at times. Tower Hobbies had them in stock a week or so ago check there and at impakt
AB, CANADA
RE: New Engine
I just put an os 18tm in my 3.3 Revo a couple weeks ago...direct replacement. I chose this over the pico for 2 reasons...price and power (still has better low end than the stock 3.3 but won't chew up and spit out your drivetrain like a Pico 26 will!).
KY
RE: New Engine
I firmly believe it has a lot to do with gear ratio, driving style and luck if you bust your truck with a picco or not. Mostly luck, good or bad.
FL
RE: New Engine
i run maxxs with both the picco 26 and os 18,if your hard on the throttle go with the os ,its much more forgiving on the drive train than the picco,and still will haul *****
AB, CANADA
RE: New Engine
Great choice...you won't regret it. With the stock Revo pipe it's a blast. I think I might grab a Trinity pipe off ebay...then we'll see what it can do!
RE: New Engine
ORIGINAL: l3asher
I run a modded Picco Max 26 in my revo for over a gallon with no signs of wear.
Did you ever run the .26 Max without the mods first to give a before and after? I too am interested in this engine but with mods out the door.
