tires and glue
OH
tires and glue
I need to re-glue my tires, does anyone have some hints on how to do that, sounds pretty simple, but I am sure you guys have some advice on that.
ON, CANADA
RE: tires and glue
just glue one side at a time.....you can use elastic bands or zip ties to hold the tire to the rim while you glue......after you have the tire bead glued into the slot in the rim and its dry put a bead of CA glue allthe way arround the wheel where the rubber meets it...
RE: tires and glue
I just pull the tire back from the rim and pour the glue on the bead, kep pouring till it runs all the waay down to the bottom of the tire. then roll the tire back and fourth with my hand using some pressure. Then just keep doing it for all the tires.
