Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Monster Trucks > Traxxas Monster Truck forum
Reload this Page >
Does the Jato 75cc fuel tank suffer from lean problem
Traxxas Monster Truck forum Discuss the Traxxas T-Maxx, E-Maxx, Super-Maxx and all other Traxxas monster trucks in this forum. You may also optionally discuss them in our MT general discussion forum.
Old 03-25-2008, 10:56 AM
Gustaf4096
Gustaf4096's Avatar
Default Does the Jato 75cc fuel tank suffer from lean problem
Does the Jato 75cc fuel tank suffer from lean problem?
Iam thinking of having 2 of them in my revo and I would like to hear the opinion from anyone that has experience with a Jato.
BR
Old 03-25-2008, 11:25 AM
slayerphonics
slayerphonics's Avatar
Default RE: Does the Jato 75cc fuel tank suffer from lean problem
tanks don't suffer lean problems...
The tank may not be getting pressurized right which means less fuel gets into the air mixture at the carb. and the engine could run lean. doesn't the revo come with a 150cc or 175cc tank? two 75cc tanks would only be 150cc same as the stock revo tank... maybe i'm wrong
Old 03-25-2008, 11:32 AM
Gustaf4096
Gustaf4096's Avatar
ORIGINAL: slayerphonics
Thx for you reply, the revo comes with 125cc stock, iam gonna use 2 engines however and I do not want to use two big tanks but 2 smaller 75cc instead.
Old 03-25-2008, 11:40 AM
slayerphonics
Ah, ok then there is a hopup a new tank for the revo that boost it to 150cc
I've seen some post about people getting bigger tanks for there revo
so you don't have to fool around with 2 tanks
Old 03-25-2008, 11:51 AM
Gustaf4096
Gustaf4096's Avatar
Sorry for confusion but Iam running <two> engines.
Old 03-25-2008, 12:03 PM
slayerphonics
oh my.. very creative.. alot of fabrication... turning the shocks... wow nice work.
Using 1 fuel tank not an option for that setup?
Old 03-25-2008, 12:06 PM
Gustaf4096
Gustaf4096's Avatar
Iam not competent enough on engines to answer that, I have seen that the gigacrusher uses one big tank with 2 separate chambers, I suppose they have a reason for it.
Anyone know what would happen if I use 2 Y connecttors instead?
Old 03-25-2008, 12:18 PM
slayerphonics
hmmm, Thinking about it... To try I would make sure I had both pressure lines into the 1 tank and 2 single lines going to the tank 1 for each motor.. I think using a T would restrict fuel flow and the same for the pressure lines..
But i've never done anything like this before, Just thinking on how I would approach it if I did
You should check out how the nitro pull trucks do it.
I've seen 4 engines on a pull truck I wonder how they do it
Old 03-25-2008, 01:12 PM
mustang-04
mustang-04's Avatar
ORIGINAL: Gustaf4096
wow! thats ver impressive work you done did there!
im guessing you havnt run it yet? cant wait for a vid or some pics when all finshed.. thats is nice
Old 03-25-2008, 02:33 PM
superman11
superman11's Avatar
It looks like one tanks is broken in and has been run and the other has not, how are you going to do that?
Old 03-25-2008, 03:27 PM
bashingnut
gustaf, they also make "Y" fittings that will flow alot better than a "T" fitting. i would use one tank. 75 cc tank will not be enough to warm up the engine and tune. get a 250 cc and let both engines share. check out dubro on tower hobbies for the fittings.
Old 03-25-2008, 07:30 PM
[email protected]
MJAsony2305@aol.com's Avatar
or just just cusom make yourself one LOL
see what else you can customize i mean look at your truck.
