os now acting wierd!!
NJ
my os .18 will only start when i have the throttle trim up about halfway and when it gets warmed up and im put putt putting around and tap the brakes it stalls
this never used to do this. it came on all the sudden
TX
RE: os now acting wierd!!
Check your throttle linkage. If it dies when you hit the brakes it may be closing the carb slide off. That coupled with it only starting with the trim up makes sense to be your problem. Check it out.
NJ
ORIGINAL: slayerphonics
rich low speed? idle to low,
temps and climate has been changing alot
yeah the whole car is runnin pretty rich and ill try raisein my idle when the rain stops.
