webshop in Japan (OS .18TM)?
Hi,
One friend is going to Tokyo and I just thought that it would be a good opportunity to buy a OS engine to my Revo. My 3.3 engine is still doing well after the 335F ride. I didn't toast it yet [sm=teeth_smile.gif].
So the question is basically whether you know of a webshop in Japan (preferably Tokyo) selling OS engines? I could of course call [link=http://www.osengines.com/osdist.html]OS/Japan[/link] but it would be easier if you know of a good webshop .
- If there is not a big difference in prices in Japan, then I'll go for a OS .21TM But as far as I can see from OS's webpage, the 0.18 has 1.6HP while the 0.21 has 1.8HP, not a big difference! Do you think you can notice it while bashing or racing? [sm=confused.gif]
- The engines (OSMG2112 18TM, OSMG2082 21TM) should be directly compatible with Revo but should I buy stronger gears / diff or alike?
Thanks!
Thanks!
RE: webshop in Japan (OS .18TM)?
ORIGINAL: Clymer122693
There is a O.S. HQ in the U.S.,it's in Champaign/Urbana,Il
ORIGINAL: acexxxoasis
hes from Denmark so one in the USA doesnt help....
WI
I understood the guy above me was refering you to a US dealer but your in denmark and your friend is going to be in Japan and will pick it up for you correct?
WI
http://liaison.ms.u-tokyo.ac.jp/agusta/akihabara.html
that link may be good for you? its a list of shops near tokyo
http://www.tanken.ne.jp/cate/sradicon/rank/
maybe? But I cant read japanese!
You got it right acexxxoasis [sm=thumbs_up.gif]. Those two links are just perfect!
I don't speak/read Japanese either but [link=http://babelfish.altavista.com/]babelfish[/link] can do it for me (translate from Japanese to English)
