Need help with revo.
Ok. So i got a revo alittle while back. First day this year I started it up it ran great little sluggish but still fun. 2nd day it was amazing power. doing wheelies super fast. 3rd day it seemed like i had a hard time getting gas to the engine trying to prime it. But once it got there it worked great. Now today the gas isent even leaving the gas tank. IF i take the the fuel line off the motor prime it and the gas flows up super fast. As soon as i put it back on the engine. And the gas goes all they back into the tank. I dont understand. Is this a compression problem. Maybe a leaky tank? compression from the motor? Plz help asap i wanna play before sun goes down.
RE: Need help with revo.
sounds like an air leak to me...did u change your fuel lines? check the o ring around the gas tank...thats what happened to mine. did u seal your engine?
ok i just tried again
now im getting great fuel pressure but now i cant keep the temps down and it has a racing idle after a high speed run. Is that a carb leak?
did u go back to factory settings first? i usually richen up the LSN some and that'll put the idle down some then after mess with the idle adjustments.
sounds like an air leak for sure check every where take off the engine and cover it with soapy water and blow in fuel like w/ air filter hole plugged and exhaust hole plugged
ORIGINAL: [email protected]
