New 3.3 Engine idles high and runs lean
CA
I dunno what it is, I checked for leaks and really can't figure it out.
Put in my new 3.3 and went to the break in. Right away I knew something was wrong because it was idling rather high (the idle gap is stock, about 1mm). HSN is 4 1/2 turns out from close and the LSN is at stock setting, A little bit out from flush.
it reached 250 deg on IDLE...... At 4 1/2 turns out, it should be spewing out oil at idle but nothing. no oil, it only spits out oil if i rev it a little.
The only thing that's old on it is the header and exhaust that I carried over from my 2.5... i couldn't find any leaks but there must be.... what can I do?
When I took it on the street, at 1/2 throttle it ran fine, plenty of smoke and i could tell it was running rich. But at full throttle, it screams and I know it's lean just from the sound it makes.
At 4 1/2 turns on HSN , past the flush on LSN, it's pulling wheelies...... There has to be a leak but WHERE!
By the way, break instructions are being from This thread by FuelMan 3-4 posts down. http://www.rcuniverse.com/forum/m_2786285/tm.htm
CA
RE: New 3.3 Engine idles high and runs lean
New Fuel lines....
Fuel tank is still the old one from 2.5 but the seal is TIGHT. I'm very positive that is not the issue but to be sure, I will retro-fit the Savage tank (which is brand new) onto the Tmaxx and see if that helps. Thanks for the idea.
Would a leak in the header area cause this? I looked my header over and it seems to be good but Maybe I am missing it so just wondering.... I thought if there was something amiss in the header area, that it would leak oil or smoke would come out but that area is CLEAN.
I think tomorrow I'm also gonna take the carb off and seal it with some high temp silicone.
Any other ideas?
Any other ideas?
AZ
ORIGINAL: n19htmare
I've had one heck of a time with the fuel tank in my Revo. I decided to buy my own O-rings... and I get a REALLY tight seal (so tight I have to PUSH the lid closed... and it *POP*'s when I open it... ) However, if something gets screwed up on that seal, it throws everything off.
ORIGINAL: n19htmare
New Fuel lines....
Any other ideas?
New Fuel lines....
Any other ideas?
