Break in with new pipe?
FL
Hello I just got a new TRX 3.3 and I got an aftermarket pipe. Can I break the engine in with the aftermarket pipe or must I use the stock one?
Xtfreak.
Xtfreak.
RE: Break in with new pipe?
My engine has never seen the stock pipe. About half a gallon through. It's one of the fastest at the flying field.
Started with the Imex pipe and changed over to the THS after breaking 2 header pipes.
i thought revo came with a dual chamber resonator and if your gonna chunk that you can send it my way.
PM me if your feel like sending it to me for cheapo.
FL
I broke mine in using a trinity pipe with no problems. One thing i do though is i idle the first tank do like 2 steps of the traxxas break in, idle half a tank then finish the break in...
Personally and this is just me; I too would break it in with the stock pipe; that way the pipe wont affect ur needle settings nearly as much; because if u put a different pipe on it right off the bat; then u probably will have to change the needle settings from break-in settings to compensate....just my thoughts here.....
