Damn T-Maxx....
Damn T-Maxx....
Got a T-Maxx... We swapped a 3.3 on it and it runs incredibly good... when it runs. New everything really, plug, engine, starter, tires/body/suspension, new servos... For some reason the truck runs great for about 5-10 mins... after that things get rough and the truck will eventually stall (w/ about 50% fuel left) and then either
A)Take forever to start again
B)Not start at all till the next day...
Any ideas? Between this and the Rustler I'm ready to trade the Rusty for a Tamiya Durga and the T-Maxx for a new Revo...
RE: Damn T-Maxx....
Sounds like u may possibly have a air leak somewhere either in the fuel tank itself, or in the lines. Have u tested the tank and lines for leaks? If not, then take the tank off, then put it in a sinkful of water and blow into 1 of the 2 fuel lines, if u see bubbles coming from either the tank or the lines or possibly both, then theres ur problem right there....If not then I would also check your gasket(s) and o-rings that sit under the carb neck, and on the backplate, and also check the fuel tank lid seal for possible wear or possible nics or tears...
RE: Damn T-Maxx....
ORIGINAL: svavrek
Not certain... Need to invest in a thermometer, it was pretty hot...
