hey revo guys, need some help with the front diff.
ok, i was running the revo (2.5r all stock) and i lost the power to the front end. it wasnt all the time but most of the time the front wheels arnt pulling, and it is a "binding and griding" sound when you roll it, clutch is fine, not that. tranny seems fine also.
i took the front diff out and all the gears look fine, ring and pinion and also the spiders look good. but i found peices of what looks like it used to be a blue silicone o ring inside the diff cup. traxxas website doesnt seem to have an exploded veiw of just the diff. both output gears have blue seals on them, so there not missing. are there more then one in there? it almost seems as if the spiders are spreading to far away from the output gears, so im guessing there is suposto be more there?
any pics you guys have would be great also.
Thanx in advance.
Isaac
Thanx in advance.
Isaac
RE: hey revo guys, need some help with the front diff.
like this item on ebay
http://cgi.ebay.com/Traxxas-5381-Rev...QQcmdZViewItem
i have those 2 little blue seals in there, one on each output gear , but i dont have that little white washer. is that a shim? and is there just one needed?
ORIGINAL: overdrivest
Your front differental went to heck. U will have to buy new gears and such.
like i said, gears are fine.
thanx hillfiger big help! looks like i just need that washer and ill be set.
Thanx again!
Isaac
KY
ORIGINAL: Nighthawk z450
Thanx again!
Isaac
Thanx again!
Isaac
The washer is a Gray Teflon Washer if it matter it comes with the Traxxas REVO Diff Carrier / Rebuild Kit link for it below.
[link=http://www.impaktrc.com/product_info.php?products_id=126]Traxxas REVO Diff Carrier / Rebuild Kit[/link]
cool thanx alot, looks like thats the washer that was shreaded in the dif cup, causing the spiders to open wider, causing skip in the output gears.
