Tmaxx basher?
AZ
Tmaxx basher?
what would it take to make a tmaxx able to withstand most crashes, and hard hits with one tire? Can any one tell me if the parts im getting are good for the first question?
1. RPM A Armes
2. RPM shock towers
3. RPM bumpers
4. RPM bulk head braces
5. Aluminum bulks
6. RPM skid plates
That is all i think i would need, please suggest any items if i missed any.
Thank you
1. RPM A Armes
2. RPM shock towers
3. RPM bumpers
5. Aluminum bulks
6. RPM skid plates
Thank you
NC
RE: Tmaxx basher?
some people may say no aluminum bulkheads but i have some and they are great. the rpm bumpers aren't necessary, but they do look cool.
i would add:
-titanium hinge pins and turnbuckles
i would add:
IA
RE: Tmaxx basher?
RPM is good, better than aluminum at least.
I see in your sig you only have the .15, get the wide arms then, should make it more stable in turns, shouldnt flip as easy.
My dad ran his T-Maxx and he broke two dogbones at the track. The first was the 3.3 ones and then he replaced it with a 2.5 and snapped both of them. Maybe it is a weak point and you should get CVD's for it.
NC
RE: Tmaxx basher?
ORIGINAL: JATO TO THE MAXX
AZ
RE: Tmaxx basher?
i already did the widemax with rpm a armes, and the stock driveshafts are the same as on the tmaxx 2.5.
so back to the original topic were do you get titanium hinge pins? and i was planing to get the 3.3 nuckles, and drive shafts
NC
RE: Tmaxx basher?
here are the hingepins...
http://www3.towerhobbies.com/cgi-bin...&I=LXEMC9&P=ML
they're really good for only $16
VA
RE: Tmaxx basher?
rpm is good stuff but it can be broken, trust me,
as for the lunsford pins they are good too, they bend quite easy i think tho, i bent 2 of mine right bad,[:@] i got a hammer and a 4x4 and they straightened right out !!
NC
RE: Tmaxx basher?
ORIGINAL: xtremes15
AZ
RE: Tmaxx basher?
as for the lunsford pins they are good too, they bend quite easy i think tho, i bent 2 of mine right bad, i got a hammer and a 4x4 and they straightened right out !!
back to the original post, so now on my list of stuff to get to make my truck ablt to take pritty much any hard hit from any angle is,
1. RPM A Armes
2. RPM shock towers
3. titanium hinge pins
5. Aluminum bulks
6. RPM skid plates
7. 3.3 Drive Line
VA
RE: Tmaxx basher?
i broke the arm on a botched landing , all the force of the truck on one wheel i guess done it, that is how i bent my pins too , i am not ragging on either brand RPM or lunsford , both of them are great, the stockers shure didnt last as long as the others
as for your list, the other items look good as well ,
i am thinking of getting the steel MIP center driveshafts tho , my 3.3 shafts break alot on me, just a thought for ya
AZ
RE: Tmaxx basher?
ORIGINAL: novakmaxx
You should get alum bulk heads. I have broke a lot of stock 3.3 bulk heads bashing me t-maxx and e-maxx.
see
how did you break them, and what did you hit to bend the hinge pins?
1. RPM A Armes
2. RPM shock towers
5. Aluminum bulks
6. RPM skid plates
7. 3.3 Drive Line
1. RPM A Armes
2. RPM shock towers
5. Aluminum bulks
6. RPM skid plates
7. 3.3 Drive Line
