issues
issues
hey can u guys tell me since my engine keeeps burning up glow plugs and it stalls out and wont start up for w while how i need to turn the needle.........there seems to be smoke coming from the pipe............i got my 2.5 and today i switched to 0.s. lc3 hot plugs and monster horsep[ower trinity fuel. ( still having same issues )
WY
RE: issues
Sounds like your running rich. The princible for tuning the needles is the same for using a screw driver lefty loosey (richens the truck) righty tighty (leans the truck).
TX
RE: issues
use the traxxas med super duty long plug and retune. It sounds like your tune is off. Your plugs should last at least a half gallon with a good tune. That has been my eperience. I have also had horrible luck with mccoy plugs.
RE: issues
well the guy at my lhs said that they wer the best plugs that he had ..........just placed an order for a new 3.3 5 minutes ago ao i can start all over again this time wit a temp. gauge so that will help me tune right?.....wat shuld the temps. be?
RE: issues
Your temps should be between about 240-270... But you cant always tune by temps you want to make sure you have a good smoke trail and good acceleration i think is the rule of thumb for tuning...Correct me if im wrong..
You also might want to consider sealing up your 3.3 before you even drop it in.. It sounds like the people on here that havnt had tuning problems with their trx engines are the ones that have theirs sealed up...i mean thats not going to be 100% awesome tune but i mean its not hard and since your already have the engine out why not right?? Im getting ready to seal up my 2.5 because i cant seem to get it to hold a tune..Hopefully i just have an airleak....
RE: issues
ORIGINAL: slurp91193
how do u seel an engine?
To seal a engine; u can use something called air-seal, or even better yet and more widely available; use sensor-safe silicone to seal the carb, engine backplate(around the outer edge of the backplate), and seal the edges around the high and low speed needles; just make sure none gets inside of the needles because it can and most likely will clog the needles preventing fuel from flowing through the needle assembly.
RE: issues
some pics?
noob.....lol
and to get the fuel lines off do u just yank.......and how do u put them back on?
some pics?
noob.....lol
Well dont quite "yank" on them or u might put a hole in them or something, but gently pull on them, they should pop right off the fuel inlets they are pushed onto. As for gettign them back on just the reverse goes, just gently push them back on, in some instances u might have to use just a very small amt of force to get it back on, but nothing very hard....and at that point u should be good to go. Hope this helps ya. [8D]
RE: issues
Here are some vids on how to tune an engine. (Note: not the same truck but same concept).
[link=http://www.youtube.com/watch?v=oSmMzpZM_As]Part one[/link]
[link=http://www.youtube.com/watch?v=BJFsJAxNoRg&feature=related]Part 2[/link]
Here is a vid of how to seal an engine: [link=http://www.youtube.com/watch?v=6xwDy-I0Z4I]Clicky[/link]
