removing clutch nut on 3.3
Just as the title states; I need to be reminded of how to get the stock 3.3 clutch nut off; as its been awhile and I need to know what size nut driver or whatever I have to use.....thanks for the assistance....[8D]
PA
RE: removing clutch nut on 3.3
I believe it's the 7mm and you need to put something in the other end of the shaft to hold it from moving, like an alan key. Let me know if u need help with setting the slipper cluch back up when your done. so u don't overtighten the nut. good luck
ORIGINAL: futureboy1969
OH
you use the size that fits the nut!!! DUH!! Did you finally get your new clutch set up? is that why you are starting to operate on tha Revo?? just wondering... [8D]
My Feedback: (52)
I need to know if there is a better than stock clutch for general use becouse I have my brand new OS .21 TM motor that I'm ready to install but don't want to use the stock clutch if everyone thinks there is something I'd be better off using, now's the time to do it if I'm going to.
OH
try searching for one of the 3 shoe set ups... those seem to be pretty good as compared to a stock clutch... the 3 shoe set up allows for more 'bite' than stock... if i were you, i would look for one of those, and BTW, steer away from INTEGY... haha... good luck, SB13
