TM 523 install, what do I need
Just got the 523 today and hopefully tomorrow I can get it running. For the 1st gen maxx what can you recommend for me to do other than performing a .21 swap? I have the motor, mount, pipe, but don't have the flywheel nut...should I get a new traxxas nut or another brand?
I can't imagine it's any different that any other motor swap but fot thise that have swapped this motor is there anything I should know??
Are the bearings the same size for the clutch bell?
RE: TM 523 install, what do I need
Bump to add I have the pro .15 version and not the 2.5 so the engine accessories don't seem to mate well. Will I need the 3.3 engine parts or 2.5 or either?
well i don't have a tm523 but i upgraded my first gen tmaxx to 4908 spec(tranny, driveshafts, motor, 4wd) and all that i mentioned is made bigger and tougher to handle the trx 3.3's torque. So....start there! I would suggest upgrading to cvds etc...
Your going to hate the rb 523 you should not of got it. Send it back get the picco the rb 523 is just full of bugs!
I gurantee you will have throtle linkage prolem and the left turn lean bug!
My rb 523 had half a tank of nitro in it and the ****ING cod rod SNAPED!!!!!!!!!!
I have not run my RC monster trucks in over 2 months now as i am so PISSED off
ORIGINAL: FrAnCioS
