stampede xl-5 trans or motor problem
my stampede xl-5 has some kind of problem with its transmission or motor im not sure. i was doing some wheelies( reverse than forward) and then it starting making clicking sounds and the rear drive was loose.
can anyone help me figure out whats going on and what i need to fix it im kinda new?
My Feedback: (325)
RE: stampede xl-5 trans or motor problem
Hold wheels while spinning the motor , when you find the part that is not turning you find problem.
Motor,pinion,spur,clutch,inputshaft,idlergear,diff gear,outdrives,shafts,axles,pins,hexes,wheels.
That is the order and I'll guess it is the idler gear since it is clicking.
OH
Sounds like you stripped a gear in the trans. That method of doing wheelies will do that quite easily.
Consult your manual for aid in disassembly or you can download one here:[link]http://www.traxxas.com/products/electric/stampede/trx_stampede_views.htm#manual[/link] If you don't have it.
And since your slipper is likely overtightened, generally has to be in order to get wheelies in that fashion, you should adjust that too.
If you're not comfortable taking the trans apart, perhaps your LHS will do it for you. Though they might charge you for labor.
