Traxxas Monster Truck forum Discuss the Traxxas T-Maxx, E-Maxx, Super-Maxx and all other Traxxas monster trucks in this forum. You may also optionally discuss them in our MT general discussion forum.
TRX3.3 rebuild
Old 09-05-2008, 08:31 AM
Rawlpower
Default TRX3.3 rebuild
Hi guys
I'm putting a new piston and sleeve in my TRX3.3.
When I was disassembling the engine, I never noticed which way around the piston goes.
Does the cut out at the bottom of the piston face the carb, or the exhaust?
Thanks!!
Old 09-05-2008, 04:18 PM
andy530
Default RE: TRX3.3 rebuild
try going to traxxas.com and look at the manual there is a place in yhe manual that shows you how to rebuild your engine.
Old 09-05-2008, 06:01 PM
t-maxxmaniac
http://www.traxxas.com/PDF-Library/TRX33_explode.pdf try this
Old 09-05-2008, 07:21 PM
cmerritt
here ya go... http://www.traxxas.com/support/kb_se...lding%20engine different engine but same idea.
Old 09-06-2008, 07:38 AM
husted
hey, the cut part goes towards the carb, so when it rotates it does not hit the crank.
Old 09-06-2008, 11:19 AM
justin_92_92
and if you put it in backwords.....It will spit nitro out the carb...been there before
Old 09-06-2008, 11:57 AM
husted
and then you have to buy a new piston and maybe other parts.
Old 09-08-2008, 01:17 AM
Rawlpower
awesome, thanks for the help guys!!
Old 09-08-2008, 10:35 AM
matts6887
matts6887's Avatar
Yep, like the others have already eluded to, if i am remembering correctly, the notched part goes toward the exhaust port....hope the rebuild goes well for ya....[8D]
Old 09-09-2008, 02:55 AM
splcrazy
yes the cut part of piston faces the clutch bell and the little oil hole at the bottom of the rod faces the same way
Old 09-09-2008, 10:44 AM
cincicycles
What's the cost difference in a rebuild vs the exchange program? Is it worth it to rebuild? I'm pretty new to nitro so I know this will come up at some point. Thanks!
Old 09-09-2008, 11:21 AM
matts6887
matts6887's Avatar
ORIGINAL: cincicycles
U are definitely better off doing the exchange program because by the time u add up the cost of a new piston, sleeve, and connecting rod; it will end up costing more than the engine replacement plan(ERP). So, the ERP is definitely the better way to go as doing that only costs about 110-120 us where as new parts for the rebuild can add up to 130 bucks or more in some cases...
Old 09-09-2008, 05:12 PM
newgst
IMO the best way to go is buy a new engine off ebay for the same price the ERP costs and that way you have the older engine for parts
