Cltuch Plates
Cltuch Plates
My clcutch plates keeep breaking. I bought more, got to about half a quart of fuel and another one broke.
www.dannyn.info
The first two pictures are the first set, and the second set of pictures that is on the Revo 3.3 model 5308.
Why do they keep breaking at such a premature rate. I have two more sets so I have some more sets to play with, but I would rather not blow throught them so quickly. Any suggestions are greatly appericated!
www.dannyn.info
RE: Cltuch Plates
Well a little chip out of one of the shoes is not a big deal at all. If you are running the slipper too loose it might possibly do that but i am not sure. I would try tightening it up some (but make sure it can still slip)
OH
RE: Cltuch Plates
Have you checked to see if it's always the same one that breaks? I mean on the same arm of the pressure plate. I'd mark it and see if that one goes first. Once one goes the others will follow, so keep an eye on it. This would indicate a casting flaw in the pressure plate. And look at the friction plate closely for any spots that look like they may be worn slightly more than the rest. This would indicate a similar flaw in the backing plate. Assuming those haven't been replaced or that this issue arose after replacing them.
You could try replacing the rest of the slipper assy. and see if that helps
RE: Cltuch Plates
Ok, thanks.
I will throw another set on and mark the location where the old one broke, and see if the same one is breaking evertime.
I was thinking about stopping by my dealer to make sure that I set everything up right.
Thanks again.
Thanks again.
RE: Cltuch Plates
ORIGINAL: newgst
RE: Cltuch Plates
Yeah, thanks. I do not think that it was too tight. My dealer just got some Integy aluminum clutch shoes in, so I may buy those. I have two other sets of regular ones, so I may as well run those through before I get the new ones.
