T-maxx transmission
NY
T-maxx transmission
I was wondering if the single speed conversion is anything worth getting. My reverse doesn't wanna work most of the time. I am use to having trucks that don't have it. I wsa thinking of taking it out. Is there a such thing as a two speed forward only conversion?
CT
RE: T-maxx transmission
yes of course, there are 2 separate conversions for the transmission. A forward only conversion which simply removes the reverse component. It doesn't affect the 2 speed hub. There is also a single speed conversion which takes out the 2 speed and makes it 1 speed. I don't know if the single speed removes the reverse.
IL
ORIGINAL: nitro rc
do a forward only conversion. that way you still have 2nd gear. its only like 10-12 bucks. Get the traxxas one. you get get better throttle response because of all the weight your taking out, and yes the reverse setup does have some weight to it, you will like how it performs.
