Revo will not move, engine winds high
My Feedback: (17)
HI
My Revo is having a problem moving. When I give it throttle it doesn't move and the engine just winds up high. I already checked the Spur Gear and Slipper clutch, they are in good condition. Could it be the clutch shoes under the clutchbell? I removed the clutchbell to check the condtion and the shoes look fine to me and the spring is still there, its not broken. With it all put together should the clutchbell be able to spin freely or should there be friction? How can I tell if the clutch shoes are worn out?
My Feedback: (17)
HI
RE: Revo will not move, engine winds high
Oops, I meant to say clutch bell moves freely, flywheel is nice and tight. I changed the original post so it says clutchbell.
sounds like ur clutch is toast man. Double check ur clutch shoes and spring, and yes it is normal if there is a very small amount of "play" in the clutch bell....usually a high winding sound indicates a clutch bell problem....
GA
If the flywheel is tight and the slipper is good and tight then it's either in the clutch shoes of something in the transmission itself. You should be able to localize the problem by starting the truck and applying a small amount of throttle. Just watch the spur gear. If it is moving (speeding up and slowing down) in response to the throttle input then the issue is either the slipper or in the tranny. If the spur does not move - or you can easily hold it with your finger - then the issue is the clutch shoes/springs/flywheel.
My Feedback: (17)
HI
Dave,
The spur gear does not move. So Im going to assume its the clutch shoes. When you say flywheel do you actually mean clutch bell? If not how do I check the flywheel?
when you put the clutch on your motor the flat big round thing is the flywheel it slipps over the collet and gets locked down with the clutch nut the thing ontop is the clutch bell and you want it to be able to spin free inside are the clutch shoes if they look good and the flywheel is tight and the spur looks good and the slipper is not verry loose this stinks but the next step is opening your trannie up and doing a full check of all the parts and gears .
My Feedback: (17)
HI
ORIGINAL: dkastil
But how do you explain the spur gear not moving. I could see if the spur gear was spinning and the truck didn't move then it would be the tranny. But the engine rev's and it seems like the clutch shoes arent doing their job of engaging/putting pressure on the clutch bell which in turn would spin the spur gear. If I push the truck by hand the spur gear will spin. So Im guessing the tranny is working.
then all it could be is a fryed pads or mby you broke the pins that hold the pads on the flywheel or thew came loose . and when you say the spur is not moving is the flywheel spinning or slipping you say it is tight so i guess not ,but still check it
My Feedback: (17)
HI
dkastil,
you got me thinking about the tranny so I just tore into it and sure enough a gear was stripped. Its either the foward or reverse gear, I can't figure out which one it is. But I still think the clutch shoes could be replaced, they look a little shiny as if they are worn out. Thanks for the advice.
now that is is apart you might as well get a forward only kit they are stronger and better ,or you can just ebay a whole new trannie for around 30 bucks and still rebuild your old trannie with a differnt ratio
MD
Sounds like the flywheel collet to me. remove the clutchbell and shoes and make sure the flywheel nut it tight and the flywheel is tight with no play. If you tighten it and there is play you need a new collet/bushing.
ORIGINAL: beachbrada
dkastil,
dkastil,
CA
dkastil,
dkastil,
have u tried replacing the clutch shoes and spring? Because I would definitely consider trying to replace those and seeing what happens when u go from there....because in addition to the stripped trans gear; it could very well be the shoes and spring that is shot....
CA
ORIGINAL: matts6887
