Picco Red Dot question
TX
I just my Red Dot in and I forgot to order a mount for it. I have a Revo 3.3 and a T- Maxx 3.3. Instead of waiting on one thru the mail is there any other mount I can use ? That I can go to my local hobby shop for . The mount in the Big Block conversion kit wouldnt work, will it?
MA
RE: Picco Red Dot question
I will work if you take the last tabs off the mount. And find a way for the linkage to line up. But the picco mount is what I use. I have both. When you get the mount if you gring off material on the mount where the adjuster screw is you can use more cluthbell and spur ste ups. Your choice.
no just get it up to around 200 run afor a few mins 3 or 4 then bring the piston to bds let it cool repeat a few times then run for a few more mins mby 5 to 6 repeat then run it for a few more mins up to 10 between break as you progress threw the cycles you slowly ramp up how much trigger you use ,break in is easy just keep tthe temps right around 200 .
I agree on the heat cycle method posted above. That is probably the better if not the best and ideal way to do break-in on almost if not all big blocks because getting the "heat" through it is the key idea here. Like dkastil mentioned; u want it at least 200, but more idealy, around(this is just a approx. numbers, in the 220-240 range because that will ensure that the piston and sleeve are expanding enough while running. Just remember, that when u are letting it cool between heat cycles, make sure the piston is at bottom dead center(bdc)....and good luck with it once u do get it if u don't already have it....
ORIGINAL: TRIPC
Cool. I will try that. If for whatever reason the temps are not getting to around 200 should I lean it a little?
It would be better if you didnt lean it, use some aluminum foil and wrap it around the heat sink to block the cooling somewhat. That would be much better than leaning it since then you are depriving your engine of lubrication, this is a universal tip and is suggested on all engine break ins since most engines come pig rich from the factory.
Tom.
Tom.
Well, on that note; if u are still having problems getting the temp over 200 AFTER u have put the foil on the head, THEN lean it the slightest slightest amt. (like 1/16 turn leaner, but NO MORE than that)...
it is ok to lean it but just try and get it hot by running it and med low speeds for a few mins to heat up you could be ahead of the game and heat the block with a heat gun they are cheep and a good thing to have.
