could i put t-maxx 4908 difs in a 4909
RE: could i put t-maxx 4908 difs in a 4909
all the new tmaxx diffs are interchange-able in actually versions of the bulkheads. You will need to swap out the center driveshafts though as the newer diffs have bigger output shafts. the center driveshafts have the same style pivot ball/output yoke as the axle shafts. here is the link for the P#[link=http://www.traxxas.com/PDF-Library/4908_shafts.pdf]driveshaft assembly[/link]
