My Project (60+ mph T-maxx) *Car Done*
#101
FL
RE: My new project
ORIGINAL: donkeymaxx
I am going to try both ways but what i am concerned about is stopping. My rustler will skid about 25 yards before i can actually stop and that is if i dont turn sideways and flip over
ORIGINAL: superman11
This is true, but he could get the traxxas adjustable wheelie bar and put it all the way down and the front wheels would barely come off the ground
ORIGINAL: kasarn
With just 2 wheel drive it will be a wheelie king You want power to all wheels. Example Subaru WRX, Mitshibshi EVO, Nissan Skyline.
ORIGINAL: gonzobot
I would consider disconnecting the front diff. The less friction the better
#102
BC, CANADA
RE: My new project
ORIGINAL: kasarn
ORIGINAL: gonzobot
with that low of a center of gravity i doubt it would be much of a wheelie king. also how often do you see a 4 wheel drive car run on the salt flats. im not say i go there or anything im just saying from what i see on tv if that counts for anything
#103
RE: My new project
Umm, yeah that is definitely a problem (the braking part..). When my Savage was in 2WD, bringing it down from WOT became a chore and it started to get a little scary. Usually it would skid more than 70ft +/- with the rear wheels being dragged uselessly behind. This isn't a problem if you have a dedicated open area to run on, but if you run on the street like me... well you might want to stick with 4wd. Don't bother with a wheely bar, if you set the truck right then it wont wheely. Gearing it up with some suspension tuning will kill any wheelies, make the rear end very soft and you will need all the gearing you can get to get past 60mph.
Tom.
Tom.
#105
TX
RE: My new project
Here are some good updated pics..
The size difference of the big block to my basher..
The ride height..
Parts waiting to go on including the revo spec slipper assembly....
What it should look like..
Sitting beside my other trucks...
I think i am going to have an issue with my throttle brake linkages []
The ride height..
#106
RE: My new project
by mill you mean truck correct? and yes i got the axial .28rr.
ORIGINAL: cat samich
the 4x4 might keep it more stable at high speeds, try it both ways. could you post pics of the new mill side by side with the factory one? im trying to get a visual size comparison. if i remember right you did buy an axial right?
ORIGINAL: gonzobot
no mill as in power mill the engine, im just trying to see the physical size difference between the 2.5 and the axial. could you sit them side by side alone and snap a pic? preferably with the axial out of its protective force field lol i mean plastic bag
thanks-cat
#107
TX
RE: My new project
thanks-cat
ORIGINAL: gonzobot
thanks-cat
#109
TX
RE: My new project
ORIGINAL: FRENCHBLUE72
I turned my carb around on my t maxx what kinda of chassis is that? It looks identical to mine
#112
RE: My new project
The ride height..
The ride height..
Looks like you need a different header too. I had the same problem.
#115
RE: My new project
Looks like ya got some pretty sweet lil "toys" there donkeymaxx; will probably be even better once u get the problem(s) ironed out....and yes good luck with that!!! [8D][8D]
#116
TX
RE: My new project
from what it looks like now my header should be ok. The chassis is so big i shouldnt have a problem. I got more parts in the mail today and i am about to go work on my truck i will post pics later.
#117
RE: My new project
#119
TX
RE: My new project
The revo spec slipper clutch kit installed
before....
after.....
Here is the stock 22 tooth .8 pitch clutch bell on a big block. For everyone who is thinking about doing a big block you will need the Traxxas #s 5422 (Flywheel nut) and 5426 (Spacers and shims).
before....
after.....
#121
RE: My new project
Looks good... I wish I would have stayed with the stock spur and clutchbell setup on my BB. I kept hearing it won't work from people on here... when the motor and 1/8th CB, clutch, spur, and flywheel got here I noticed all you need to make the stock CB work is a spacer. Now all the 1/8th stuff is out of the packaging so I'm stuck with it. Guess I need to talk my LHS into carrying MGT spurs and slipper pegs.
I love seeing the difference between the trx and the axial... There is nothing like a BIG BLOCK
#122
RE: My new project
Looks good there donkey!!! like ur choice of engines too!!! just make sure u get the correct gearing for both engines because if not, it probably will cause "un-wanted" results....
#123
TX
RE: My new project
ORIGINAL: Montana Mike
Looking good. Is that 2.5r out of your 4 Tec?
#124
TX
RE: My new project
ORIGINAL: fabrimacator21
So what spur gears are you using that are 1.0mm pitched? Can you send me a link?
#125
RE: My new project
They are for the LOSI mgt. Uses the stock tmaxx slipper clutch setup though so I don't think you can use em unless you ditch the revo clutch.
http://www.hobbypeople.net/gallery/372138.asp
I like this setup because it has less rotational mass then the revo clutch. As long as you run pegs in all the holes your good. The drawback is you can't use traxxas slipper pegs and around here mgt spurs and slippers are hard to find.
