Twin & Multi Engine RC Aircraft Discuss the ins & outs of building & flying multi engine rc aircraft here.
Ziroli DC-3
Old 09-14-2003, 04:55 PM
SteveD-RCU
SteveD-RCU's Avatar
Default Ziroli DC-3
I've started assembling my DC3 and will show some photos as I progress.Also I would appressiate any input.Anyone else building one of these?...Steve
Old 09-14-2003, 05:01 PM
SteveD-RCU
SteveD-RCU's Avatar
Default RE: Ziroli DC-3
It takes up all my building table space at 99".This is from a Precision Cut kit which fits together nicely.At this stage I have'nt glued any parts yet.
Old 09-14-2003, 05:05 PM
SteveD-RCU
SteveD-RCU's Avatar
Just trying on the nose section for size.Fits nicely and the glass work is very good.
Old 09-14-2003, 05:07 PM
SteveD-RCU
SteveD-RCU's Avatar
Aft section
Old 09-14-2003, 05:11 PM
SteveD-RCU
SteveD-RCU's Avatar
Robart retracts/tailwheel and cowls.I'll be stuffing a pair of US41's in them.
......more later...Steve
Old 09-14-2003, 06:49 PM
William Robison
Steve:
I realize it will raise the engine cost somewhat, but don't you really think such a nice scale project deserves a more scale engine than the US 41?
I'm waiting for a pair to go in my F7F. Couldn't resist them.
Prices and specs here:
http://www.technopower.com/
Bill.
ID:	61345   Click image for larger version
Old 09-14-2003, 07:04 PM
SteveD-RCU
SteveD-RCU's Avatar
Acually I initally wanted to install radials Bill but the bigger Technopowers dont fit and the smaller ones dont have the power,Also the Saito 170's are just a bit too big for the scale cowls.I could make a bigger cowls and would involve enlarging the nacelles a bit.Could be done.The 170's would be nice.I could also opt for a V twin.....
Old 09-14-2003, 07:40 PM
William Robison
Steve:
Have you considered the OS R5-300? It's about the same six inch diameter of the A7 and B5 Technopower, and a lot more powerful.
Or for less money and even more power the ASP five cylinder radial is a full 4.0 cid, one third larger displacement than the OS. If you have room that one would do very well.
I just wanted more than five cylinders showing, so that meant the Technopower A7. Granted, it's only 1.35 cid, but my f7f issmall enough to fly with 0.40 two strokes, so my only problem will be trying to make up for the weight.
Bill.
Old 09-19-2003, 04:02 PM
F86_SABRE
Hi,
At the moment I am building the Ziroli DC-3 albeit I have a fiberglass fuselage that mates very well with the rest of the Ziroli plan. I wish to know:
1. what the "normal" anticipated weight of the plane is.
2. information of how the plane flies (i.e. any vices).
Like Steve, I will be doing the DC-3 in the Canadian Air Force scheme although not with the double lightning flash as shown in Steve's photos. In this regard I would appreciate any further information as to the light grey FS number found on the lower part of the fuselage and on the wing underside.
Any ancillary information or tips one might have on the Ziroli DC-3 would be most welcomed.
Regards
Reuben
Old 09-19-2003, 07:18 PM
SteveD-RCU
SteveD-RCU's Avatar
Hello Reuben;45-50 lbs is the projected weight.What engines are you using in your 3?I dont know of any vices the DC-3 has.Its supposed to be the best big twin to start out with,although I plan on getting some twin time on a Twin-Air 40 first.
Do you have any pics of the glass fuse?...Steve
Old 09-20-2003, 02:57 AM
F86_SABRE
Hi Steve,
I had in mind in using either the MOKI 30cc gas engine with rear induction, rear exhaust (or sideways) or the MVVS 30cc gas too or the Tonini 25cc (german gas engine).
I wish to keep on the lighter side of this if possible. I also have in mind in using the MICK REEVES fiberglass covering instead of the traditional balsa/fiberglass system but still have to find out how much I need.
Its no problem in putting up a few shots of the fiberglass fuse...getting out doing it is the problem! heheheh
Steve...have you got any documentation regarding the FS number of the light grey that was used on the underside by any chance? I got my color scheme from a book about the DC-3 I have of the real DC-3 Canadian Airforce. Another scheme I like is the OTIS SPUNKMEIER scheme but unfortunately I dont know which type of fonts they use in their wording.
Catch you later.
Reuben
Old 09-20-2003, 06:33 AM
SteveD-RCU
SteveD-RCU's Avatar
Not sure about the paint numder for that grey but can look into it Reuben,have you
checked out Douglasdc3.com ?
Steve
Old 09-20-2003, 07:06 AM
warbirdz1
Steve....Keep in mind that your plane is gonna require some nose weight.......might as well install the weight as "horsepower".....have seen several with G-38's(Rear exhaust makes a nicer fit) and they fly quite nicely.......If you are inclined and a "Radial" can do the job for you.....even better.......as always with a twin........reliability is the key.....if the engines aren't performing well....don't fly it til they do.........specifically even more so with a taildragger.......nearly impossible to keep a good track on the T/O roll with engines that don't turn an identical RPM( within 200 RPM)......not the easiest to fly on one engine but will do it with adequate power.........Good Luck....Keep us posted ......Bill......
Old 09-20-2003, 10:17 AM
SteveD-RCU
SteveD-RCU's Avatar
Thanks for the input Bill.I'll stick with the US 41's I have,because they are a reliable engine and they have some weight...Steve
Old 09-20-2003, 10:25 AM
SteveD-RCU
SteveD-RCU's Avatar
I'm working on the tail surfaces at the moment so the fuse is on the floor.
Old 09-20-2003, 11:53 AM
SteveD-RCU
SteveD-RCU's Avatar
Lower Surfaces RCAF/CF Dakota's
A good paint match for this is about a 50/50 mix of RAF 'Sky' & FS35237. A weathered 501-109 can readily be replicated by reducing the percentage of 'Sky', giving a more bluish appearance as when weathered, any green tint was 'the first thing to go'.
Cheers,
Bob
Reuben;I got this from Bob Hurst ,a technical feedback guy from the RCAF webpages..hope this helps.His email address is [email protected]
Old 09-20-2003, 12:11 PM
F86_SABRE
Hi Steve,
Thats the plane I had in mind in doing. Thanks for the color info too.
Now I am enclosing some photos of the fiberglass fuse I have.
Regards
Reuben
ID:	62494   Click image for larger version
ID:	62495   Click image for larger version
ID:	62496   Click image for larger version
Old 09-26-2003, 10:06 PM
RCPilot100
Here is a picture of my good buddies recently finished and flown DC3. Power is a pair of BME 44s - weight is 44 pounds, including 4 pounds of nose weight. The BMEs are wonderful - I will use a pair of 50s when I build my big B25. This picture is before he finished the graphics - the plane is modeled after the Classic Express N103NA. If you do a search, you can find several pictures of the full scale - and it looks exactly like Larry's finished plane.
Dan
Old 09-27-2003, 09:40 AM
SteveD-RCU
SteveD-RCU's Avatar
Larry sure did a nice job Dan.Bet she hauls pretty good with those BME 44's.Be nice to see it with the finished markings on it....Steve
Old 09-27-2003, 02:26 PM
Sturmovik
SteveD im just curious what scheme do you plan on using. Personally being a a warbird nut that would look awesome in a nice olive drab WWII covering .
Old 09-27-2003, 02:32 PM
SteveD-RCU
SteveD-RCU's Avatar
I haven't decided on which colors yet.Will probably go RCAF or some bright civi scheme...Steve
Old 09-28-2003, 04:07 PM
F86_SABRE
Another question to the list........are there any appropriate full body type pilots for the Ziroli DC-3?
Regards
Reuben
Old 09-28-2003, 05:25 PM
SteveD-RCU
SteveD-RCU's Avatar
Guess you need 2 1/8 fullbody pilots.DGA I think is one source,should be a few others..Steve
Old 10-01-2003, 04:44 AM
cmsrp
I have a semi completed DC-3 hanging in the garage that I would love to finish, but not sure if that will happen... Course, if someone needs it more than me, I could be persuaded!!!!
Here's how it looks...
Old 10-01-2003, 06:45 AM
SteveD-RCU
SteveD-RCU's Avatar
Lookin good cmsrp ;Do you have constuction of the DC-3 on hold?.Steve
