DeHavilland Mosquito
#401
RE: DeHavilland Mosquito
big thanks for the pics and the info, very reasonable on the price and from the looks of it, the spinner back plate looks to be 1/4 inch thick, that might be what I need to fit my motors with out any mods...
Thank you!!!
I am ordering some today.
Thank you!!!
#404
My Feedback: (37)
ORIGINAL: Hot Rod Todd
You will likely need nose weight, so you might as well use plenty of engine. I use twin .46AX two strokes. The December 2004 issue of Fly RC magazine has a test where they fitted twin YS .63 four strokes. Even with the 1400mah ni-cad all the way in the front of the nose, they still added a few ounces of nose weight. I would say go with the .56's, nothing less. Two Saito .82's would be really sweet! With retracts the plane ends up fairly heavy. The extra power will help you.
#407
Well got a few more flights under its belt so decided to finnish her off, painted up the Graunper 11/7's, peeled off the radiator stickers and made some more scale type ones filled and painted, and added some flight crew
lozza
lozza
#408
Hi All,
I am a new member of this group and a fan of the Jamara Mosquito. The mine fly very well with two electric engines AXI 2820/12,
BUT BE CAREFULL, There is a big error about the CG in the original doc.
Look at below the good place of the CG for a good and a safe flight...
I hope this will help you.
You will find all the photos and a video of my electric powered Mosquito at :
[link=http://uscaero77.free.fr/_avion/mosquito/index.htm]The Electric Powered Mosquito[/link]
Have fun a good flights,
BlueRider
BlueRider
#410
****SPINNERS*****
Hi all, have not been around much, been busy flying for a change. Just to let you all know Dave Brown has put some spinners on Ebay. They are made to exactly the profile that the Mossie used as the drawing used was taken off the profile of the real thing. (See page 15)
They are the best you will get and are absolutly spot on. See picture below. Dave said he intends to make some more but is very busy at the moment.
Have fun
Have fun
#412
No Idea he just said could I post on here thart he has them on ebay.
What have you searched under? Maybe he hasn't put them up yet. I spoke to him last night.
I'll have a look myself and let you know if I find them.
#414
Here is a video of my electric conversion.
http://www.rcgroups.com/forums/show...437#post5660175
There is also a thead on the build
http://www.rcgroups.com/forums/showthread.php?t=523476
#415
Sorry wrong link
This is the video link
http://www.rcgroups.com/forums/showt...37#post5660175
have a look at this
have a look at this
#416
Well, I've done it. I've finally bought one.
Need to decide on engines though.
I've read the posts and most people have their favourites but which would you guys consider the best to put in it? (Contentious I know)
Saito FA50/56 - ok?
RCV 58CV - slim design - less cowl bashing
OS FS52S - good reputation
Obviously reliability is a big factor here (even with a [link=http://www.rcuniverse.com/forum/m_4211050/tm.htm]TwinSync[/link]) but weight will be an issue (heavier the better I guess) as will the sound
Cheers
Chris
Saito FA50/56 - ok?
Cheers
Chris
#417
If you want the sound, you should go with 4-strokes. I think nearly any motor could be as reliable as you want, just make sure it has enough brake-in time (the older the engine the better).
I bought 2 new Magnum 52 FS, they are identical with the OS version. Maybe not as good finish. I had them both on my engine-break-in-mount for about 3x 250 cc tanks, and I think the run nice, and nearly same rpm. These Magnum are just cheaper them OS.
But the Saitos would be very lovely in the plane. I had one FA-72 and earlier I thought about buying one more. But I got some response that they would be too big for the cowls.
For the weight, I plan on douple receiver (2x 5-cells) batteries on a MPX RX-9 receiver. Glow-driver for the engines. And maybe a special ACT voltage regulator. All just to make some use of the extra weight up-front you need.
#418
ID
I just started assembling a Mossie myself. Thanks for all the tips fellas. I'm thinking of using a pair of O.S. FSR .40s. Theoretically, it will go about like a rocket. I probably have some reinforcing to do.
#419
OS .40's will be OK, but not a rocket by any means. It can easily handle them without re-enforcing. I'd opt for the .46AX's, you can then get a bit more thrust which helps a lot on take off. Don't go by the recommended power, whoever came up with that was a bit off.
#420
ID
Well, those old FSR 40s are a bit more powerful than the new ones, or should I say a LOT more powerful. Pretty comparable to a Tigre 51, just without the weight.
#421
ID
Also, I was wondering if anyone had any input concerning mechanical retracts to use. The ones they make for the mossie don't look very durable.
#422
I am using those from 3DXHobbies.com
http://www.3dxhobbies.com/store/cata...T_cat_310.html
I got them a long time ago, and they seem very sturdy. And I use Robart struts 65xL+R (I think it is).
#425
ID
Well I feel dumb now. That's not bad on the weight. I'm thinking of using robart mechanicals, though. They should work fine and they're about half the price. I just wish someone made some scale retracts for this particular model.
