Eletronic engine syncronizer **SUPPORT **
#1002
My Feedback: (13)
Aloha Guys,
I have an older Twin Sync too and also just purchased from Down and Locked, their DL530 interface, for electronic ignition gas engines. I've had my Twin Sync for over five years...do I need to up date my unit ? I'm building a twin 35cc gas engine model and I'm going to use these two units in my model.
Soft Landings Always,
Bobby of Maui
Bobby of Maui
#1004
In terms of glow engines Laser, Enya and some Saito engines can be reversed. Laser and Enya have separate cams so need retiming. The Saito engines have a single camshaft, so you need to change this for one from the other side of the boxer twin. Perhaps you can do the same for the Saito gas engines.
#1005
#1006
Hey Dgiatr,
Here is an update on our throttle creeping issue. I swapped out the throttle servos and used the hextronic hxt12. Mainly because I had them in my box. No other reason. After re-setting all the other settings - high/low and sync point - I ended up with this result.
At any more than 50% throttle the servos would hold station no problem. Great news. I can fly around and not worry about the power falling off. Now - below 50% - the power would drop down to the sync point over about 2 minutes. Originally, I had my sync point set at 2500 revs. I changed this to 3500 revs. Now when it pulls the power back it will stop at the sycn point and hold there. This power setting will still allow me to land with power and have the sync engaged. I have done 10 flights with these new settings and it is all working flawlessly. I know others have said in earlier posts that 3004 servos will be fine but it would appear that more powerful servos will ensure that it all works properly.
I hope my findings will aid in your setup and help get it sorted.
Regards from,
The Kiwi Bandit.
Regards from,
The Kiwi Bandit.
#1007
Hey Dgiatr,
Regards from,
The Kiwi Bandit.
Regards from,
The Kiwi Bandit.
will put 2 hextronik 12k in my tigercat too and i will let you know then.
thanks again,
Jim.
#1008
Hey Dgiatr,
#1009
Howdy Rocketman,
To answer your question. You are absolutely correct about the throttle creeping. It is now only happening below 50% of stick travel. Since I am not using less than this for normal flying it is not a problem. I can work around the lower setting since I am usually setting up for a landing approach.
It was Ron who suggested using the stronger servo. Some info on my setup first. In a previous post I mentioned that I had fitted much stronger springs behind the barrels of both my carbs. The extra load on the servo to overcome the drag was causing a severe dead band effect. This dead band was affecting the way the twin sync controlled the throttles. As it turns out - the stronger servos have helped to overcome this problem.
Kiwi Bandit.
Kiwi Bandit.
#1013
There was an update some time ago. I have an older unit (removable chip). The problem is that they (WikeMike) did not mark the chips with the version. So if one does upgrade, which they might do if we have enough units to send in at one time, you don't know if you upgraded or just had them rewrite the same firmware. Two of us are waiting to possibly do the upgrade. Also, it would be very nice to know what had changed from the old version to the newer version.
Bottom line is even D&L can't tell you for sure.
#1014
why dont you send an email to WikeMike ([email protected]) ; he always responds to emails. i think its better to send to his personal email account not via RC UNIVERSE.
i have two twinsync units , one in an esm bf 110 and one in an esm tigercat , they two work flawessly.
Jim.
Jim.
#1020
Hi,
Regarding updating the older board with the removable chip.
Direct from Wike - Ron word.
I think he made some small board changes and that is the only reason he moved from 2.3 to 2.4.
So I am going to put my 2.3 in my next build.
BTW I cannot find a manual for 2.3. I have 2.4. Would appreciate it if someone could send me the 2.3 manual (info sheet).
Cheers,
Craig
It is not necessary to upgrade the 2.3 to the 2.4
Cheers,
Craig
#1022
Hi I have purchased an un flown DC3 with 2 x Saito 100 four strokes twinsync and dl506 glow drivers.
The twinsync seems set up correctly but I have no information on the glow drivers .
Is there a manual?
I have twin sync set up so in mode 5 both red and both yellow led are on so the glows should run all the time the props are turning without the aux channel.
My glow driver boards both have a yellow led on but neither engine will start using the glow units but are fine on separate glow sticks?
I must be missing something as I have put the glow against the head and spun the motors and still have no glow. I have checked continuity from plug to engine and through twinsync and all look good.
I have even replaced the engine bolts to steel from coated ones in case it was a grounding issue?
Can you offer any advice..
Regards
Mick
Is there a manual?
Regards
Mick
