TWIN ENGINES, ONE FUEL TANK?
My Feedback: (213)
NY
I AM BUILDING, RE-BUILDING, A SINGLE ENGINE MODEL INTO A TWIN. IS IT FEASABLE TO USE ONE FUEL TANK TO FEED BOTH ENGINES OR SHOULD I USE 2 TANKS?
CA
RE: TWIN ENGINES, ONE FUEL TANK?
Why not? Your only concern will be that both engines can get their full draw of fuel.
I believe a .40 will use about 3/4 oz. per minute at full throttle, so if you had twin .40's you would need lines large enough to supply 1 1/2 oz. per minute. Since it would only take about 20 seconds for you to fill a 6 oz. tank thru the same fuel lines, starvation of the motors shouldn't be a problem unless you were talking about BIG motors.
Bad idea, in my opinion.
How about pressure? You can't adjust the needles with only one engine running because the tank pressure leaks out through the other muffler. When one quits, the other will go lean due to lack of pressure. You are just asking for trouble.
There are 2 feasible ways. One is to install a smaller carb that will draw fuel without muffler pressure. The other is to use a pump.
I am on my 23rd twin and I have learned to use the KISS principle. You know, Keep It Simple, Stupid. Yep, my buddy and I learned this the hard way. Fly anything in a single engine, but for a twin, buy the most reliable engines you can, break them in first, set them up individually, run slightly rich and enjoy. Use 2 tanks.
My Feedback: (27)
SC
If you used a check valve on the pressure line of each engine, wouldn't that negate the loss of pressure from the loss of one engine?
I don't see a problem with a single tank for two engines provided everything is plumbed correctly. There would be three lines utilized at the tank. Use two clunk pick-ups (one for each carb) and a single pressure / overflow line connected with a good quality tee fittting from each engine's muffler along with the aforementioned check valve.
The only hassle with this set up is fueling. You would need to disconnect the overflow line between the check valve and the tank for the overflow to function correctly. That and pinch off the carb line to the opposite engine to prevent flooding. Obviously, access to these lines would be neccessary. Use a tank twice the size (DUH!) of what you would use for a single engine application.
Now, having said all that, if you CAN facilitate a dedicated tank for each engine, that WOULD be the preferred method.
Good luck and have fun!!!
Al
Al
Bad idea. I have attempted to use one tank with two engines and it doesn't work. The interaction of muffler pressures will not allow setting the high speed needles. The engines will run but cannot be synchronized. One engine was off it's maximum rpm by 1000 rpm.
Ed and Evan are correct. Keep it simple.
Since you received conflicting advice I suggest you experiment on the bench which is easy. If the engines do not run properly on the bench the concept certainly does not belong in the airplane.
Bill
Bill
ORIGINAL: Bad_Daddy
Hmmm - I hadn't thought of the tank pressure changes if one motor dies, and that would be a problem. I guess you showed me!
Bill
IN
Here is my latest project, six engines and of course six tanks. Nothing less.
John
John
I agree......K.I.S.S. I've tried tried several single tank setups over the years and never got satisfactory results.
Rod
All that being said there is a safe way to accomplish this, but it is not using a pump
The way that you might want to consider is to use a Kline Regulator setup if you want to go scale and do not have good room for multi tanks to get a flight time you would be happy with
if you use 2stroke you can go with crankcase pressure with a check valve on each motor and if 4stroke use muffler with check valves.
You would then put a regulator on each motor and they will only let fuel through if there is venturi vacuum
Mine has worked well, but it is in a single engine setup
I will say that the 2stroke pressure will inflate the tank some and that is how I can say that it will work for multi as the inflated tank still does not push past the regulator.
Good luck on your project
My Feedback: (14)
TX
ORIGINAL: martys40s
As a rule one tank per engine is usually the more reliable setup providing there is room for the required capacity tank in the nacelle.
TX
If you are using gas powered engine with walbro (pumper) carbs, one tank will work fine. My flying pal has campaigned a DC-3 for 8 years using one tank. He originally used Qudra 35's and then switched to
G-38's. One tank was fine.
If you are using glo engines and muffler pressure, I'd use two tanks.
TX
Above answers that say do not do it.. are CORRECT PERIOD!! Ok,,you won't listen...Ok,,listen to Ed Moreman and the clyme system....Ok,,you asked for it.
http://www.rcuniverse.com/forum/m_24...tm.htm#2447788
Don't do this, but it will work,
Twinman
PS Sorry, the person who refered to the gas engines that have fuel pumps, is of course correct also, but not glow.
Twinman
My Feedback: (14)
TX
ORIGINAL: twinman
Twinman
Twinman
Correct period? I really doubt that.
TX
Ok Ok,,Regulators work too..Ha Ha Picky Picky, What I am getting at is that it adds unnecessary complexity and expense to make it reliable. You cannot just connect two engine to one tank without additional components.
Twinman
Twinman
IN
Another thought...When there are two engines on one tank and the tank starts to go dry, it is likely that one engine will die first and as you then attempt to get the plane back under control with a single engine - and are very busy with that activity - the second engine will either slow down and die as the fuel funs out OR go lean and speed up just before it quits! Not a really good thing to have happen in my opinion.
ORIGINAL: Newc
Dont forget that this is a very stable fuel flow to the engines and the only time you should have a problem is if you dont tuse a good engine start up regimine or you forget to set some kind of reminder timer.
BTW there is only one regimine that I have found to really work:
1. start one engine and after short warmup set the needle for high (with tach or ear) and then back off needle one or two clicks, approx 300 R's,
2. shut off first engine
3. start second engine and tune to peak then back off needle just like on first engine
4. start first engine
5. DO NOT TRY TO MAKE BOTH ENGINES SOUND EXACTLY THE SAME WITH THE NEEDLES NOW. The reason I say this is that you have tuned the engines to their most reliable setting and any thing changed is asking for trouble.
Remember that unless you are trying to fly Pattern or IMAC you are just straining at nats bottoms and is it really worth the hassle and possible engine flame out
ORIGINAL: flycfii
twinman- after reading your thread on the B-17, I formally suggest that you change your name to "Four-Play".
No I wont go there at this time (your safe for now Tm)
