Go Back  RCU Forums > RC Airplanes > Twin & Multi Engine RC Aircraft
Four Stroke engine sizes on twins >
Twin & Multi Engine RC Aircraft Discuss the ins & outs of building & flying multi engine rc aircraft here.
Old 03-22-2003 | 05:48 AM
NJD
My Feedback: (14)
Default Four Stroke engine sizes on twins
Hi - I was wondering if you might be able to post what four stroke engines you used on your twin. I am currently building a Jack Stafford Twin Commanche with a 72" ws, btw 9 and 12 lbs.
I would like to know the engines used, the props used, and the performance of the airplane - I am still trying to decide on which four stroke engines to use, and want more feedback from others with similar sized twins. It would be great if you could post your altitude - I live at 6,000 ft, so I know I would need larger engines.
Thanks - NJD
Old 03-22-2003 | 06:03 PM
Hi!
I'm building a Marutaka DC-3 (started in -79 ) but lost interest in it after a couple of years but started building again in -2000.
Plan is to use two OS .26 FS engines and 10x5 props (I have plans molding my own 3-blade carbon props for it). Goal is to make it fly at 3kg using Giezendanner electrical retracts (takes 5 seconds to retracts wheels).
I have made new cowls and oilcooler for itin glassfiber instead of the balsa and aluminium ones made by Marutaka, more scalelike than the original.
Plan is to use Oracover chrome film sanded down with fine 2000 grade wet sandpapper so that the shine goes away and in small pieces on the wings so that it looks like the real thing.
The same on the fuselage or might use aluminium tape in small pieces.......have not decided yet.
Fueltanks is a problem on this ship....I have soldered my own 4 oz fueltanks from tin sheet , horseshoe shaped, so that they fit behind the 2,5mm plywood firewall and give room for the 9cm in diameter balloon wheels when they are retracted. Having the fueltank centrally placed in the fuselage like the plans says is not what I would call a good place for it!
Hope to fly it this summer.
Regards!
Jan K
Sweden
Old 03-25-2003 | 08:04 PM
best at this alt , Satios or os.
one guy has satio 52? on a aerotech bf110 72"
another os 70 on 80" wing b-17
I had satio .65 on 72" p-38(over powered),
Ys.53 on 72" aerotech mosquito( ys 53 dicontinued and un reliable, but sounded cooool..)
American eagle b-17 123", Satio .65 3 blade 11x7s
Denver r/c eagles v.p.
Flying at cherry creek state park
Old 03-25-2003 | 10:41 PM
staggerwing's Avatar
Default Dualist
i have Saito .56's on dualist, flying at 6000'. Purrrrrrfect.
Old 03-26-2003 | 01:19 AM
My Feedback: (15)
Default Twins
Flying a Kyosho DC-3 with OS 40 Surpass. Nothing spectacular, but fly's real nice
