twin up roar
NJ
twin up roar
was thinking of doing a up roar 60 as a twin, set it up like a twin cut, fuse are close and one is shorten than the other to keep the props in close, heres the ?????????? would one use 2 60s or 2 46s as the wing will only be about 8 in longer and planes weight maybe 3 lbs more but hopeing for less.............any help would be great and or pics if someone has done this...........................thanks
