Go Back  RCU Forums > RC Airplanes > Twin & Multi Engine RC Aircraft
 Kavan Brake battery options >
Twin & Multi Engine RC Aircraft Discuss the ins & outs of building & flying multi engine rc aircraft here.
Old 10-26-2007 | 10:56 PM
brentp76's Avatar
My Feedback: (14)
Default Kavan Brake battery options
Has anyone had any experience using a 11.1 volt pack on the kavan brakes? I am working on a Art Johnson P-38 and would like to utilize these brakes, however weight is starting to creep up there and would really like to use a lighter battery. I emailed sig, and I seemed to get the canned answer, has anyone out there tried the higher voltage packs?
Old 11-03-2007 | 11:01 PM
Boomerang1's Avatar
Default RE: Kavan Brake battery options
I have used the Kavan brake but only on 7.2 volts from the ECU pack of a turbine model. Like you I did not want to carry yet another battery just for the brake.
Have you considered using a voltage regulator just for the brake if you are worried about burning it out?
I used one on my B-36, I did not want to risk draining my reciever pack if my servo driven retracts went horribly wrong so I tapped off the flight packs with a 5 volt regulator. It works perfectly & weighs next to nothing.
The Kavan brake is quite heavy & bulky, have you considered a pneumatic brake system, common on turbine jets?
These are very light & work well. Unfortunately, like it seems with everything associated with turbines, the biggest weight reduction will be to your wallet! [sm=lol.gif]- John.
