kmp dc3 due november 30th i just ordered one
#178
Hi yankphan,
The CG is at 120mm or about 4.7 inches as the instruction suggest.
With the two 20cc RCGF Gas engines i only needed 1.8 pounds in the nose to balance and it flew very well...
The wings are supposed to be glued in one piece but i made my outer panells bolt on with one Dubro wing bolt which was easy to do and is enough...
Hope tis helps,
Mario
Hope tis helps,
Mario
