Unusual R/C Discuss Airships, Blimps, LTA, VTOL, Ground Effect Vehicles, Hovercaft and more.
Mono-Phan Technology
Old 10-05-2014 | 05:49 PM
UN.RCONT.OL's Avatar
Default Mono-Phan Technology
New 1100W 3700Kv motor
Over 1.7kg Max Thrust
New yaw vane design
New 100% Carbon fiber protective frame
Carbon landing gear with spring dampers
New ball joint thrust vector mechanism
Pics and first ever test flight:
https://www.youtube.com/watch?v=hjkJxwi00Ig
Old 10-10-2014 | 07:45 AM
Second flight purpose: Test flight time, test stability.
Slow drift on yaw axis stopped me from flying it around the park. May need to reset the flight controller or yaw sensor may have completed life.
Flight time is around 4 minutes. Carbon frame is pretty strong and stable. Good, easy landing if you approach with the right angle.
New motor has lots of extra power.
Good flight...
https://www.youtube.com/watch?v=8rV9zj5MW7A
Old 10-11-2014 | 04:03 PM
Now, this is much better!
https://www.youtube.com/watch?v=eV8pYQmcs10
Old 10-17-2014 | 05:37 PM
https://www.youtube.com/watch?v=5-4h...ature=youtu.be
First ever flight with an on board camera...
Old 10-18-2014 | 01:20 AM
I guess this 1 axis gimbal setup should help take better videos...
https://www.youtube.com/watch?v=hiPhSAxn568
Old 10-19-2014 | 02:33 PM
First flight video with the 1 axis nano gimbal...
https://www.youtube.com/watch?v=oYmss08wSa8
Old 10-25-2014 | 07:31 AM
New flight video from this morning...
https://www.youtube.com/watch?v=mF1AIDHVQcU
Old 10-30-2014 | 07:35 PM
Some higher G maneuvers...
https://www.youtube.com/watch?v=86ZmSG-y64A
Old 11-07-2014 | 04:19 PM
This is the last flight of the new module with the old flight controller.
The old flight controller will keep on flying on the first module which will be modified.
The new module is modified to work with a multiwii flight controller.
You can check my blog “mono-phan technology with multiwii” for the first pics.
https://www.youtube.com/watch?v=NXrr8Nz8QfA
Old 11-26-2014 | 02:55 PM
Some fun flying with the wing module
https://www.youtube.com/watch?v=HdSXoNwNDeQ
