Go Back  RCU Forums > Electric Aircraft Universe > VPP - Variable Pitch Prop 4D flying
 Flying using a VPP system - switch or lever >
VPP - Variable Pitch Prop 4D flying Discuss VPP - Variable Pitch Prop 4D flying in this forum
Old 05-01-2008 | 06:21 PM
Default Flying using a VPP system - switch or lever
Does the plane fly normal in every respect until you use the pitch change. Is the pitch change controlled by a switch or the left throttle lever? On my Realflight it seems as the Vpp is controlled by a toggle switch. You put throttle lever down and flip the top toggle switch for full reverse. Is this the way it should be?
Old 05-02-2008 | 03:29 AM
Rodine Air Force's Avatar
Default RE: Flying using a VPP system - switch or lever
No. Throttle stick should control the pitch.
Forward stick position = forward pitch
center position = 0 pitch
Back position = reverse
