Walkera #4 Fixed Pitch Helicopter Forum
#6977
RE: Walkera #4 Fixed Pitch Helicopter Forum
Also, the rear prop kinda pulses
Whats that mean... mayb gyro or sumfin
might be just the trim who knows, goin to ma step dads work tomoz, HUGE 20x20x20ft ware house WITh a slipery floor!!!!!
#6978
My Feedback: (20)
PA
Ok, trimmed my main blades even more, lifts off and flys great, tailrotor blade took a dump though, so I made a new one, which worked but slipped on the shaft so the gyro was freaking out, then ejected itself and she spiraled in, no damage though, now I am going to replace it with an EDF, a GWS one, which one do I want for this thing, it has the 33 main motor, and am currently flying a 11.1v li-po that is 910mah, flight time is good and wieght and balance are right on, so all I need it a ducted fan tail and it will be alot tougher and better in the grass...
#6979
ANyone want to field this question,
I have a Walk 4. And it's fairly new. The power to the tail motor goes away when more throttle is applied, thus I loose control. I don't see any pot on the rx, like the 22e has or in the instructions. Any idea other than buying another rx or even another brand rx.
I have a 22e and 60. I got this to get my son into the heli game, and this thing is pretty fun to fly.
JSGP51
JSGP51
#6980
It could possibly be the trim, or even a servo, try checking all the connections/charging battery, or the gyro might even be failing, if not, call/message the person you bought it off and ask [&:]
#6981
NY
ORIGINAL: JSGP51
JSGP51
JSGP51
Tom
#6984
I don't think it's the trim. the heli acts fine in the first 50 % of the throttle travel. hovering low 2 to 3 feet high.
I have to start giving it more and more right to hold it steady, as I start to climb higher into a move and then it starts to slow spin to the left on it's own, as if the control is frozen. I thought the gyro failing myself. But you guys are the experts on this type if heli. Thought I'd ask you all.
JSGP51
[/quote]
JSGP51
[/quote]
#6985
NY
I have ownly painted blades, but some posts earlier said you had to strip it first than use some special paint. Most air brush theirs.
#6986
So that's possibly the gain for the gyro? Yeah I do see something there. I'll give it a try. thanks.
ORIGINAL: Mdhat
There is a hole on the side of the receiver right next to the flashing red light. Tiny philips screw driver, turn clockwise 1/4 turn at a time and see what happens.
Tom
ORIGINAL: JSGP51
JSGP51
JSGP51
Tom
#6988
I've been through a few tail motors in my 1,565 flights on DF4's. It looks like the tail motor is giving it's warning of wearing out. If you have a stock setup and the flat on the gyro adjust pot is any less than ten o'clock, then it's going fast. 9 o'clock and it may go out. That is if it started out fine at 12 'oclock. I run mine at 10 o'clock Try it at 1 o'clock and turns will be very sluggish.
A weak battery can also start fizzing out when the load of mid throttle + tail motor bogs it down. If it climbs really well, then it's the tail motor. They are like jelly beans in the heli world.
CH
CH
#6989
Whoa, I had two mini crashes today, both power loss related. First, I was coming out of a stall turn, in a left bank, building up speed, and all of a sudden the main motor cut totally out. The wire on the motor terminal had frayed and vibrated loose. Then later, I was stretching a battery, a powerful rush of wind caught me in a sideways slip, and whack on the ground. First crash, no damage, second bent the rotor head core. It's still flyable, but has a little vibration. I just changed the rotor core and a double whammy got me. Ain't these DF4's great ? That could have been a $60 day on many other helis.
CH
CH
#6990
So your saying the phillips screw in the rx is the pot? ANd I don't see any mrkings in the hole for adjusting?
JSGP51
JSGP51
ORIGINAL: Chophop
CH
CH
#6991
ORIGINAL: kingelmo
What does it mean when the rear prop pulses?????[&:][&:]
#6992
ORIGINAL: Chophop
CH
CH
#6993
MINI REVIEW: 2007 Version 1 HM4#-1
You will not need an o-ring, steel flybar or Super-Skids to get this one to hover. I didn't even take the time to balance the blades.. I unpacked it, straightened the paddles and lifted off.
Dead stable hover, nice response and reasonable climb out power on a stock nimh battery. I will try the lipo on it stock and let you know the results.
Anyway, it's windy still here so this test flight was in the garage. I will let you guys know how it really flies when the wind is gone. I will try and get some video. Here's a couple pics for now:
#6994
nah its sorted now just balanced it all and adjusted.
Thanx, but i am gonna be grounded for another 2 days or so till my rotor head arrives, can anyone tell me/ show pics on how to asemble it on????[&:][&:][&:][&:][&:][&:]
#6995
and how do you stop it from twitching when your like 8 ft away???? mine slightly twitches, then stops when i throttle up???[&:]
#6996
ORIGINAL: kingelmo
If the rotor head core is broken and the blades already in the parts box then you can skip at least one of these steps and move to usable part recovery mode!
ORIGINAL: kingelmo
1. The antanea wire comes wrapped around the left side of your skid and this is bad. You aren't supposed to have it cross back over itself. What else do you do with it on a stock heli? I don't know really. Don't wrap it around the boom though, that is even worse!
2. Your servo is binding.. If it wants to go straight but there is bindage against it then it will sit there and twitch. Make sure everything moves nice and free.
3. Bad servos which Walkera is absolutely notorous for!
#6998
My friend just ramped his helicoptr up to a 60cm main blade, 12v motor, and 20cm rear blade with extnded rear thing (forgot name[:'(])
#6999
I love the sound our chppers make when you take off, the thud thud thu noise, but faster...
yu guys have been like a family, thanks, i will definately takes pics when i can hover [:'(]
#7000
ORIGINAL: kingelmo
where should i wrap it?
http://www.rcgroups.com/forums/showa...hmentid=912437
Here's his idea:
Here's where I leached this information:
http://www.rcgroups.com/forums/showthread.php?t=326535
