need help on removing the gears !!!!
QC, CANADA
Do I have to take apart the frame in order to change the 2 gears on the heli or there is an easier way?
I just don't want to have to do this if I can avoid it.
I have removed the main shaft but the bearings and the gears don't seem to get out of there unless I split the frame which of course means major work.
Anyone ?
Thanks.
Anyone ?
Thanks.
PA
RE: need help on removing the gears !!!!
You neglected to say which helicopter you have.
Check the forum for the heli you have, you will probably get all the info you need there.
Good Luck
Don
Good Luck
Don
QC, CANADA
sorry for that, walkera 36 !!
I didn't find anything on the 36's thread but then again I have not yet been through all the 166 pages !
Thanks.
Thanks.
