Painting HL silver metal tracks
IL
Hello,
I have a question. What kind of paint do you use to paint the silver metal tracks and drive sprockets on HL tanks? Also what about a product called Blacken-it?
thank you.
thank you.
RE: Painting HL silver metal tracks
I have used that pruduct and the results were good but not as good as painting them, IMO. I simply spray a quick coat of primer and then hit the tracks with a gun metal color and then spray them with flat black and finallymist a light coat of brown . Make sure you spray light coats and allow time to dry in between each.
That looks good, i'm sure there are alot of methods,can the rest of you guys share your track painting tips? I've got a new deluxe HL Panther G coming in the mail tommorrow...It has metal gears,tracks and sprockets.
ORIGINAL: ROLLIN ARMOUR
Is tamiya paints ok for the job or is flat enamels good?
I hard about a guy using "Kurust" or smilar, that stuff you get from car accesory shops, it apparently turns the alloy lack whn it dries but goes on just like milk, unfortunately i havent seen any photos tho.
EDIT I tried using Kurust today on a smal bit of track and it didnt even change colour, so dont know where that idea came from.
Krust is a weak phosphoric acid solution and only works on ferrous metals-it turns the rust oxide into an inhert black sustance and supposedly stabilizesthesurroundingsteel-as the tracks are alloy it wouldn't work.
ORIGINAL: Der Stier von Scapa Flow
