Weatronic Support Forum Go here to get help with your Weatronic products.
Weatronic jr module issues
Old 04-13-2013 | 12:45 PM
J.F
Default Weatronic jr module issues
Hi,
Owned weatronic for many years now with no issues.
Emailed weatronic last Monday but still no reply.
Switched on my gear to check before a jet event, and my jr module is doing strange things, it is failing to start properly and will switch off on its own. I ordered yesterday a replacement cable as this seems to be a common fault, but I think now it is a problem with the module.
Could you please advise as soon as possible as I use this equipment on my twin turbine A10 and want to fly on Friday.
Please check out this video on vimeo http://vimeo.com/63607699
Old 04-15-2013 | 06:08 AM
Default RE: Weatronic jr module issues
JF,
I do not have enough experience to advise you on this problem. Please contact Jens Ackermann at <font color="#0066cc">[email protected]</font>
as soon as possible. Please report back with the diagnosis on this problem. Thanks Larry Jolly
Old 04-15-2013 | 06:19 AM
My Feedback: (15)
Many of us are following this thread I am sure. I am following with much interest as I use the same setup..scary video.
I have had episodes of being locked out but usually because I had not completed a "quick bind" or a software issue - never one where it didnt work and the it did without fixing something....
WEATRONICS - Please advise us on this finding.
Dave Dennison
12-22 gyro 3, gps (4); waiting for Wx Tx
Old 04-15-2013 | 06:35 AM
J.F
ORIGINAL: Weatronics USA
JF,
I do not have enough experience to advise you on this problem. Please contact Jens Ackermann at http://<font color=''#0066cc''>jens....nic.com</font>
Thanks Larry, I have emailed Jens, hopefully get a response. Like I say never had issues before, been very happy with my setup all these years.
I can rule out card issues and cable issues, as i have chnaged the old cable for a new one that i ordered from Wea. I have used the old memory card in a new tx module, so its not that. pretty much says that my tx system has died..but for no reason. Good job i checked over.
Old 04-15-2013 | 04:47 PM
luv2flyrc's Avatar
Does it exihibit the same behavior when it's connected to giga control/ laptop and is being powered by the usb connection? This could tell you whether it's the module itself or the adapter/cable.
Mike
Old 04-16-2013 | 11:16 AM
J.F
I've bought and changed the cable and the top module and all appears fine, so it must be the top module itself.
Am sending the old ones off to weatronic for them to have a look at and will let you know the outcome.
J
