Weatronic Support Forum Go here to get help with your Weatronic products.
12FG Flaps
Old 11-15-2009 | 09:40 PM
My Feedback: (10)
Default 12FG Flaps
Have my 12FG and 6014 set up as 2Ail/2Flap/Ailevators for a jet with flaps on a 3-position switch. I have the flap1 servo adjusted in AFR with a point curve set so the middle switch position is where I need the flap to be for takeoff and bottom switch position as landing flap . I also slowed the servo speed in AFR. Problem is flap2 has no means to adjust it in the AFR menu to the same settings.
What am I doing wrong?
Jeff
Old 11-15-2009 | 11:55 PM
Default RE: 12FG Flaps
Hi Jeff,
I think you are in the wrong forum. Your reference seems to to relate to the Futaba receiver 6014.
Gerhard
